TwinTurbo.NET: Nissan 300ZX forum - There's an easy way to do switched power. Just get
Subject There's an easy way to do switched power. Just get
Posted by ThunderZ on April 11, 2008 at 6:33 AM
  This message has been viewed 142 times.
In Reply To quick question?? posted by hawaii2z on April 11, 2008 at 02:45 AM
Message a fuse tap for $8 from Auto Zone or similar and connect to a 10 amp switched connection your fuse box. Then you run a wire from the new tap at the fuse box to the AFCII and what ever else you have there that won't blow the 10 amp fuse.
The kit comes w/ a 10 amp fuse and others w/ less amps so can size it to match your installation.
I prefer this method of tapping over soldering onto to the harness at the ECU. It's easier and you don't hack up your harness.
